Hi fellas!
Does anyone have any idea how I can fix the problems shown in the attached picture?
We would like the text to always be readable in a "smart" way (this is a kind of dimensioning symbol).
Family is attached.
Gelöst! Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
Open up the generic annotation family (Avståndslittera). Check "keep text readable" and then load it back to Mått - Ytor livar.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
@Ilic.Andrejwrote:Open up the generic annotation family (Avståndslittera). Check "keep text readable" and then load it back to Mått - Ytor livar.
Hi! It is "keep readable" but I guess it gets a bit messed up when nested into another family? (so that I can place dimensions and parameters to it, always keeping it in the middle)
EDIT: My bad, solved it now. Found that the family itself also had one "Keep readable" parameter besides the actual label (weird?). Thanks!
I'm glad if this helped. Actually, when I opened the family you attached, I saw that "Avståndslittera" had "keep text readable" unchecked.
Andrej Ilić
MSc Arch
