I have problem with dwg export in Revit. Ceiling which is visible on the view like underlay doesn't export in dwg. PDF export ok in Revit view everything ok too . Also this problem there is under on the the ground flooron the ground floor everything ok.
If it is visible on screen the underlay will be exported to DWG...
See sample export view side by side Revit/DWG TrueView
