I received a coordination model in NWD format, which I linked to Revit. The building block in the coordination model is located according to the map for design purposes - the building block is very far from the Internal Origin point.
After linking the NWD file, the building model displays incorrectly. How to solve the problem. Maybe the coordination model should be sent with a different base point(Internal Origin in Revit) ? I need to model the installations in the building based on the coordination model I received.
View from Navisworks Freedom - model displays correctly
View from Revit 2023 - model displays incorrectly
