Hello everyone,
I have a problem with Detail Item Line Based family when I want to create an array. When inserting the family it does not respect the values of the matrix and the lines are disordered. I have not been able to solve this problem, has anyone encountered this problem?.
Thanks in advance. I attach the file in Revit 2023
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Line base with array usually don't play well with each other. I would create a nested detail family and add into the group. See attached
In this case, I mostly use this workaround (don't know anything else for this):
- Create a nested Detail item with the line and an instance parameter (Length in this case)
- Load into the host family
- Align with 1 side and associate the Length parameter.
See attachment
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Thank you so much syman2000 and ralphdenhaan. Both solutions work for me. Now I will see which of the two solutions best suits what I need.
