I'm having issues with the default stainless steel material for a lot of the restaurant families in Revit 2022. They have this weir cut-out pattern to the metal. I tried removing it but all the components are in read-only mode. What is the best way to fix this?
@Anonymous wrote:
I did uncheck it, it refuses to save it or update the change within the model
Not sure why you cannot save the change but you can always replace the Appearance Asset.
@Anonymous
Is is a workshared project?
Are you editing material in the Family Editor or Project?
In both cases where is the file/model hosted?
Editing the Material is the Family editor does not change the Material of the same Name in the Project. Project Materials Rule. Edit the Project Material and assign the Project Material to the Family.
FWIW: I don't think "Metal - Stainless Steel (1)" is a stock Revit Asset. It is probably a Document Asset created from the "Stainless Steel Mesh - Holes Large" Asset.
@Anonymous
Windows permissions issue not Revit. Try the following and check if you still get the same error (in principle you shouldn't)
When you open the family...Do not double click in the browser. It does that Read only Lock sometimes
