Problem with Cloud rendering
6 ANTWORTEN 6
Nachricht 1 von 7
aoziang
454 Aufrufe, 6 Antworten
Hi guys,
I'm having trouble with could rendering. My pc suddenly cannot start cloud rendering somehow. The same file and account is still okay for rendering on a different PC.Did any of you ever came across the same situation? Got any idea how to fix it?cloud rendering issuu.PNG
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: aoziang
I have the same problem!
Nachricht 3 von 7
ennujozlagam
@aoziang hello, you can try to check it here some explanations in your problem this LINK. hope it helps. thanks
Nachricht 4 von 7
aoziang
als Antwort auf: ennujozlagam
Hi ennujozlagam
Thank you for the Link. I actually tested that link before, It didn't seem to work with this case. I even tried to reinstall the program, but also, not helpful.
Nachricht 5 von 7
ennujozlagam
@aoziang @Anonymous  hello, try to install latest updates and hot fixes from autodesk and clear your warnings as much possible and try again rendering., see if helps. thanks
Nachricht 6 von 7
aaa
Observer
@ennujozlagam
I'm pretty new to the software, may I ask by hotfixes, you mean hotfixes for Revit right? like stuff in this link: https://knowledge.autodesk.com/support/revit-products/downloads
Nachricht 7 von 7
ennujozlagam
als Antwort auf: aaa
yes, you can also go to to your autodesk account if you are under autodesk subscription and download from there.. thanks
