Problem with arcs in floor or roof
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
steveg
1056 Aufrufe, 8 Antworten
When I place an arc on a floor or roof the line work jumps making it impossible to do
Please see video
Revit 2019
OS Name Microsoft Windows 10 Pro
Version 10.0.16299 Build 16299
Processor Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz, 4201 Mhz, 4 Core(s), 8 Logical Processor(s)
Total Physical Memory 32.0 GB
Name NVIDIA Quadro P4000
Driver Version 25.21.14.1917
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: steveg
Are you in a view on a sheet?
Nachricht 3 von 9
steveg
als Antwort auf: ToanDN
In a view
Nachricht 4 von 9
But is that view placed on a sheet and you activate it to draw the floor? Or do you open the view directly?
Nachricht 5 von 9
steveg
Rhat view is not on any sheets,  it is a working view
Nachricht 6 von 9
JamesLawtonPremtech
Did you manage to resolve this problem at all? I'm having the same issue in Revit 2018.3.
When creating a floor I can draw connected straight lines but as soon as I draw an arc the lines jump away from their positions and the arc becomes almost a circle.
I can draw the shapes as model lines without using the floor tool, but even copying and pasting the lines into a floor produces the same crazed result. (attached image showing result)
Been using Revit for years and never had anything like this
Nachricht 7 von 9
sgrinavi
als Antwort auf: JamesLawtonPremtech
No I have not found a solution and have never received a resolution from anyone on anything that I've ever posted here.  I was under the impression that Autodesk was present in this forum.
Nachricht 8 von 9
da104
I've solve the problem.
Still in the sketch mode, Change your work plane set that your view is refer to.
Nachricht 9 von 9
martijn_pater
als Antwort auf: da104
Not sure what's happening there, but if nothing else you could always cut it with a void extrusion...
