Hello, good morning!
I have a problem introducing adaptive families created by 3 adaptive points along a line that I have previously graduated with points.
The problem is this: When trying to put the family along more than 3 points, putting it several times... I can't get families fitting together in curves, they overlap or there is a separation and I would like to know how I can unite families with each other or adapt to each other. Thanks a lot.
I don't understand the issue. Sounds like you want a sweep and not a repeater. Is that about the size of it?
...or is that not a repeater in your screenshot? Maybe you should post the file instead. Can you do that?
hello,
What I want to do is a linear bridge work, placing an adaptive family by 3 points along the axis of the highway, the problem is that families do not fit together by putting several times along the axis
@malonicivil1 wrote:hello,
Have you considered re-purposing ductwork for this job? Food for thought.
Hello, I want to put the family along an axis, its not a profile its an adaptive family by three points I want be perpendicular to the axis in every point of the axis and fit perfectly the 1st family with the second, the 2nf family with the third one... tHANKS
