Problem with a file 2015 when it´s opened in 2017
3 ANTWORTEN 3
Nachricht 1 von 4
270 Aufrufe, 3 Antworten
HI!
I have a big problem when I open an 2015 file into 2017 software. All the texts in the sheets appears moved.
It looks like that they have the same size , but something happen. When you open it  in 2016 everything it´s ok but when you do it in 2017 it´s like the text doesn´t fit into the text box and revit convert it,and appears in two lines instead one line as it was in the 2015 version.
Anybody can help me? pleeeeease I need a solution as soon as possible because i don´t know if my rpject is goping to be opnede in 2015, 2016 or 2017...
I´m waiting for your answers
Thnaks in advance
3 ANTWORTEN 3
Nachricht 2 von 4
Melina.Vlachousi
als Antwort auf: Anonymous
In Revit 2017 changes have been made in the way text is measured. You can find the information here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Nachricht 3 von 4
als Antwort auf: Melina.Vlachousi
Thanks a lot for the info!!
Do you know if there´s something to solve that all my texts had been resized and now they are not shown where they should be.. something to relocate where they sould be,,,
It´s a BIIIIIIIIIIIG problem cause al the sheets in my projects had been changed if i open them in RVT2017
Thanks in adavnce.
Nachricht 4 von 4
EmptySaturnV
You can edit the text styles to shrink the text to the size that it used to be and they should look the way that they did before. It may require a bit trial and error to get the right size since you will most likely be dealing with 1/64th increments.
