Goodmorning,
I have problem with view of topography surface on level 1 (screenshot 1).
If click on it appear message says "modify view range" as screenshot 2.
I kindly ask which value have to put to view the surface?
Thank's
Gelöst! Gehe zur Lösung
Gelöst von bimscape. Gehe zur Lösung
You basically just need to ensure the "Top" and "Cut Plane" of the Primary View Range is above the highest point in your surface and then (to be on the safe side)- set the "Bottom" / "View Depth" to Unlimited. Also check that Topography is turned on (as a Visibility setting) in that View
Hope this helps?
@bimscape thank's for your reply.
- set the "Bottom" / "View Depth" to Unlimited. I put that as in screenshot but the message is the same.
Also check that Topography is turned on (as a Visibility setting) in that View ==> how can control that?
Thank's
This is all that was required in your file
