hello everyone,
i have a revit question, i made a callout view for unit plan, and rotate it by rotating crop region, but now i want to reset it back to original orientation, does anyone know how to change it back?
thank you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
There is no reset button...Rotate the callout/crop region back in the opposite direction ?
Go back to the parent view and rotate the callout back to the original orientation.
If you're going back and forth, maybe Scope Boxes would be better here? Know what I mean?
Well it shouldn't be a hard guess, would it? Well unless you were rotating them randomly 21.356 for that one, 32.145 for this one and 45.2341 degrees there
how to use scope box together with callout view? i may need your guys elaborate it a little bit more. or maybe a link i can check it out. thank you
