Hello,someone can help me please, the problem was I'tried to direct link/ import to twinmotion, the roof in revit model it's there to overhanging, but in my revit it's partial border tile and there is no problem.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Are you referring to the 2" overhang?
...if so, the workaround is to inset the divided surface exactly 2".
What type of roof is it?
Did you you Datasmith plugin to sync?
Did you try as FBX?
ok thank you for your response sir, i will try export data smith, for roof only
