problem- stairs and railing
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
501 Aufrufe, 3 Antworten
I have few problems in the stairs I created:
1. The support beams of the stairs won't connect with the landing beams (see attached picture: support). Why does it happen, and how can I fix it?
2. The railing "breaks" at turns (see attached picture: railing). Is there any way to join it together?
3. Is there any way to connect stairs (with the railing and supports) to the landing of another stairs? I have 2 set of stairs because each has different riser height (see attached picture: 2 risers)
4. The end of the railing and the end baluster wont connect. What am I doing wrong?
Thank you so much!
Amit
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
with my small knowledge. I hope attached pictures about 1 & 2 can help you a little bit:
Nachricht 3 von 4
If you want a smooth, clean transition, push the upper run farther from the landing a bit.  In you case, if you could add one step to the lower run and reduce one step from the upper run.
Nachricht 4 von 4
Thanks!
That helped :leicht_lächelndes_Gesicht:
