I'd like to find a way how to show the total height of the stairs in the Stair Schedule in Revit (we have that program parameter - 'Desired Stair Height' (in grey) - the calculation Revit is making after assigning top and bottom levels.
Is this any way to show that parameter in Stair Schedule? (I can't find it...)
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Create your own "Desired Stair Height" as a Calculated Parameter that adds up the total distance between the base and the top of the stairs, including offsets.
