Problem printing Revit file to PDF - image tessellates
I am using a late 2013 Macbook Pro (OSX 10.13.6) with 16 GB RAM, Parallels 14, Widows 10 and Revit 2019.
I am having difficulty exporting PDF files. I have tried using Cute PDF, PDFCreator, PDF Architect 6, Microsoft Print to PDF, DoPDF etc. I had the same issue with Revit 18 and Parallels 13. Images attached.
Thanks in advance for your help.
Shaan
jayhar
Hi
Visit here try this
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Thanks for your quick response. I have tried all the options you have suggested but the problem persists. Occasionally I am able to print after restarting Revit and printing only line drawings (without raster). It seems that other users also have the same issue.
Shaan
Hi there, you probably already solved this but just for the record I believe I had a similar problem with a similar hardware setup.  I solved it by turning off the hardware acceleration in Revit (found in the options/hardware menu).
I'm using Parallels and I think it's happening because Revit doesn't recognise the drivers for Intel Iris integrated graphics card in my MacBook Pro (Retina, 13-inch, Late 2013).  In Revit it shows simply as "Parallels Display Adapter (WDDM)".
