I work for a window manufacturer and I have a problem with a IFC plan I got from a client.
It’s a simple building with a couple of windows and doors.
The plan is exported from Allplan.
But if I open the IFC in Revit (2018) I noticed that the height and width of the windows and doors or not visible in the properties.
We need the height and width for our production software that import the windows and doors form Revit.
And because the height and width are not visible in Revit the production software does not recognize the windows and doors.
Just to be sure I opened the IFC in a viewer.
And in the viewer the height and width of the windows and doors are visible.
So it seems that the height and width where correctly exported from Allplan in the IFC file but is lost when it is opened in Revit.
So I don’t know if this is a Revit or a Allplan problem.
Maybe I do something wrong when I open the IFC in Revit?
Or is it het way it is exported out of Allplan?
Are there people who have had the same problem?
Hi @Anonymous
Please try installing the IFC for Revit addin
Confirm if you have the latest updates for Revit 2018 installed on your machine.
Import via the addin and see if that helped resolve the issue.
See product documentation: About Revit and IFC
Looking forward to your reply update.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Anonymous
I'm sorry to hear that.
Is it possible that you share the Revit model and a journal to investigate further? Let me know and i can share a private folder link.
Viveka CD
Hi @Anonymous
I have created a private folder and shared the link to your email.
Please upload your journal and files.
Let me know if you have issues accessing the folder.
Viveka CD
Hi @Anonymous
Thanks for sharing your files. I will test and let you know for an update.
Viveka CD
Hi @Anonymous
Thanks for checking back with me. I apologize for the time.
Unfortunately, we haven't got a result yet, so I will have to kindly ask you to wait a little more.
Thank you for your understanding. Thank you very much for your patience.
I will follow up as soon as I have an update from our development team.
Feel free to ping me @Viveka_CD
Viveka CD
@Viveka_CD wrote:
Hi @Anonymous
Did you find a solution ?
I have the same issue and I can't find a way to solve it ![]()
