Problem opening Allplan IFC in Revit
19 ANTWORTEN 19
Nachricht 1 von 20
PetukhovMV
880 Aufrufe, 19 Antworten
Good afternoon. I also faced the problem that IFC from Allplan in Revit and Navisworks does not recognize geometry attributes (height, width, area, volume). Have you failed to understand what the problem is?
19 ANTWORTEN 19
Nachricht 2 von 20
Viveka_CD
als Antwort auf: PetukhovMV
Hi @PetukhovMV
Can you share your file and other diagnostic data to test further?
Let me know and I'll provide more details and share a private upload folder.
Nachricht 3 von 20
PetukhovMV
als Antwort auf: Viveka_CD
Hi, @Viveka_CD
Thanks for the answer. How can I send a test file?
Nachricht 4 von 20
Viveka_CD
Hi @PetukhovMV
I've shared a private folder link with you.
Let me know if you can access this folder and when you are done uploading.
Please see the article:  Revit - Collecting and sending diagnostic data to Autodesk Technical Support
I look forward to your reply update!
Nachricht 5 von 20
PetukhovMV
Hi, @Viveka_CD.
Uploaded the test file. The file was created in Allplan. The basic properties of elements (volume, area, perimitre, etc.) are not visible in Revit and Navisworks
Nachricht 6 von 20
Viveka_CD
Hi @PetukhovMV
I received your journal file and IFC file.
I will also need a few other files to investigate further. Please extract data files using the Collector v1.9b.zip  from this article and upload these files to the private folder as well.
Let me know if you have any questions!
Nachricht 7 von 20
Viveka_CD
Hi @PetukhovMV
I'm checking back to see if you've had a chance to upload the required files.
Nachricht 8 von 20
PetukhovMV
Hi, @Viveka_CD.
I uploaded the file.
Nachricht 9 von 20
PetukhovMV
Hi, @Viveka_CD.
I do not see these parameters.
Nachricht 10 von 20
Viveka_CD
Hi @PetukhovMV
Thank you for your response!
I received two IFC files and the screenshot.
I will also need diagnostic data for further investigation.
Please see the article below on how to extract data from your machine and upload these to the shared folder as well.
Article: Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know if you have any questions on the above and when you are done uploading the requested files.
Looking forward to your reply update.
Nachricht 11 von 20
Viveka_CD
Hi @PetukhovMV
I just wanted to follow up here, did you have a chance to look at post 10.
We would need diagnostic data to proceed with this case. Can you post a quick journal and required data to the folder.
Looking forward to hearing from you!
Nachricht 12 von 20
Viveka_CD
@PetukhovMV
Thanks, I received all your files. I have logged this with development and will follow up for any updates/ progress.
I will let you know if we need more information from your end.
Nachricht 13 von 20
Viveka_CD
Hi @PetukhovMV
I'm looking at your journal and observed that you are on the first customer ship -  Build: 20180216_1515(x64)
' Branch: RELEASE_2019. Please update to 2019.1
Please see the article on How to tie the Build number with the Revit update
To make sure that the issue you are seeing is not something already fixed in one of the product updates, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Let me know if there is any change after installing the updates.
Meanwhile, we will continue investigating your files!
Nachricht 14 von 20
PetukhovMV
Hi, @Viveka_CD
Thanks for the info. Upgrading to 19.1 did not solve the problem
Nachricht 15 von 20
Viveka_CD
@PetukhovMV Thanks for the quick response - I will add this to your case details.
The investigation is in progress! Smiley (fröhlich)
Nachricht 16 von 20
Viveka_CD
Hi @PetukhovMV
Can you send us another Revit model with screenshots? Apologies, as the previous file you sent, had some issue with the further testing.
Looking forward to your reply.
Nachricht 17 von 20
PetukhovMV
Hi, @Viveka_CD
I upload  2 file.
Nachricht 18 von 20
Viveka_CD
Hi @PetukhovMV
I did not see your file 2, can you specify the file name and try uploading again to the same shared folder?
Thanks!
Nachricht 19 von 20
Viveka_CD
Hi @PetukhovMV
Can you please send us the file? I am unable to progress without the copy.
Nachricht 20 von 20
Viveka_CD
Hi @PetukhovMV
Unfortunately, the file you shared does not help the team investigating, this new RVT file is totally different from the IFC's attached...
Can you please tell us a parameter in the 2x3.ifc file that doesn't appear in Revit? It looks OK to me, but as I said the IFC file comes in as Russian and it is hard to be sure.
Again- the parameters listed in your image ( in English, which makes me think this is a different file, but maybe your allplan is in English) seem like calculated ones from that viewing application and not actually part of the IFC file.
Can you please clarify the above.?
