I just sketched some stairs. First I made a run of stairs. At this time they showed in both views. Then I converted them, they still showed in both views.
Then I adjusted the layout in plan view and accepted it.
After this only the bottom step shows in 3D view but the whole thing shows (correctly) in plan view.
I ran through this process twice, same result.
There are other stairs I edited previously (on Windows 8.1, before I went to Windows 10 & faster MB, CPU, graphics card).
They are fine.
This is in 2 3D views.
Revit 2018.2, Windows 10.
Any ideas?
GChapp
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Press VV (Visibility graphics overrides) at 3d view.
press the + beside stairs.
makes sure that every thing is checked, especially the treads/risers.
Mostafa Elashmawy
