Why can't i sketch a stair case like attached picture, where the first riser is under the last risers, i mean that there will be an overlapping in the stairs, the last step shall be over the start of the stairs
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
That is because the sketch is all on one plane and Revit sees the lines that you know are on a differnt level as intersecting each other and thus cannot generate the stair. Create the stair by component instead of by sketch, and then adjust it.
Take a look at this.....
Which is why. Model by component - and then tweak. That is how I got mine to work.
SIgh. Here goes -
1) Model stair by component
2) Select Stair
3) Edit Stairs
4) Select the run of the stairs that you need to edit the step
5) Click Convert
6) Close the warning
7) Edit Sketch
8) The selected run will have green and black lines like this
9) The green lines are Boundaries. The black lines are Risers. You can edit them
10) Edit the last step till it looks like this
11) Click the green check mark twice to accept the change. You have edited the sketch.
yes now i got it, when i edit stairs by comp. it only edits the specific run, not all the stairs..
thanks very much manager ![]()
