Problem in graphics while Linking/Importing CAD
2 REPLIES 2
363 Views, 2 Replies
I have a CAD detail that I want to import into Revit. I used both options Linking and Importing CAD just to see if that helps. When I import the drawing, few hatches are invisible, few lines are too heavy. I have attached the images of autocad exported , revit exported products and the setting that I used while importing the CAD file. I appreciate your suggestions.
2 REPLIES 2
a_meteni
In addition to the above link which covered the Linking process in depth, my suggestion is avoid mixing AutoCAD and Revit as possible. Even if these are typical details and not related to model elements you still can detail them with Revit rather than Linking AutoCAD file.
