Problem in Exporting to Navisworks (Revit 2023)
sadehghani
sadehghani
When exporting from Revit 2023 to Navisworks I go to Navisworks Settings>Convert Element Parameters and choose "All", however the "Revit Type" Properties does not appear in Properties palette.
I repeated the whole procedure in Revit 2022 with the same options and every thing was "OK"
Did any one encountered the same problem with Revit 2023 Exporter?
RyanCameron
Are you sure you're not in some sort of Demo/Viewer mode?
Try downloading the file exporter plugin here:  https://www.autodesk.com/products/navisworks/3d-viewers
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
RyanCameron
For more info:
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
sadehghani
Ryan,
I'm in 3D view.
What I do in Revit 2022 is exactly like 2023 however in 2023 the Revit Type properties is missing.
We had the same issue back in 2013 when some geometry were missing while exporting to Navisworks
RyanCameron
I'm seeing the same thing you are.   All, None or Elements.
sadehghani
Ryan,
In Revit 2022 if we choose "Convert element properties:All" we see the "Revit Type" properties in Navisworks.
In Revit 2023, the "Revit Type" is missing
