I´m trying to export these revit files in to dwg files but, for some reason, it is not exporting the image below.....but it exports great to PDF file. Any suggestions?
Many thanks.
PDF exporting
DWG exporting
Gelöst! Gehe zur Lösung
@jjjoao2 Please uncheck below option in DWG/DXF Export Setup.
Please see below capture image.
Thanks & Regards,
RJ
@jjjoao2 wrote:Hello,
Many thanks.
PDF exporting
DWG exporting
@Anonymous, it worked with 90% of the sheets....for some reason it didn´t work with the rest.
Thank you very much for your help.
