Problem about steel connection in schedules
I want to show the mass and cost of the steel connection in schedules in Revit 2017. How can I do that?
Alfredo_Medina
There is a parameter for the weight of the steel member by length, and there is a parameter for cost. You have to enter the values and then set those parameters to calculate totals. Or, use shared parameters in families of structural connections, add those parameters to the schedule, enter values and calculate totals.
I can't find any dimension for the steel connection and I have no idea how to put ' knee of frame' into 'material takeoff' schedule.
hi press on the steel .go to edit type you will see in the new list the word [cost] right the price you want.go back to the scudule add cost you will see the waor caculate valua press on it you right new name and down  choose cost
