Printing
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
williams_cory_a
270 Aufrufe, 6 Antworten
Printing
I am having a difficult time printing a simple drawing of a courtyard layout (attached image). The building is an imported CAD image and the rest are from revit. I cannot figure out why its printing in half-tone. I have tried changing the line weights for the CAD import but still cannot get it to change. What are the steps I should take to print drawing darker?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: williams_cory_a
Choose vector, not raster, under print settings.
Nachricht 3 von 7
williams_cory_a
als Antwort auf: ToanDN
Vector is already selected.
Nachricht 4 von 7
Hi.. There might be three conditions:
  • Check your visibility settings (VV) for imported category. Halftone should be unchecked.
  • If you are using any worksets check same visibility settings.
  • Check Print setup in Appearance the colors should be black lines.
If still the issue is not resolved then you can do one thing, select the CAD file and use override graphics in view for black color.
Nachricht 5 von 7
pieter1
Is it also printing as vector? Sometimes something in the drawing will force it to raster print.  I can't tell whether it's printing as vector or raster because you've provided a jpg. Do you also have a pdf?
Also, when you say 'I tried changing the lineweight of the CAD": where exactly did you try to adjust it?
Nachricht 6 von 7
Checklist for a successful vector printing (not all maybe applicable to your view but do go through what are):
- Visual style should be: wireframe, hidden, or consistent colors
- turn off Shadow
- turn off Silhouettes
- turn off Sketchy Lines
- turn off Depth Cueing
Nachricht 7 von 7
williams_cory_a
I was printing in shaded. Such and easy solution that took me a whole do to fix.
