Printing with images in titleblock
2 ANTWORTEN 2
Nachricht 1 von 3
NERDASORUS
254 Aufrufe, 2 Antworten
Hi
I have pictures in the title block, the problem is revit export these images to the location of the DWG file. And if I delete these picture files, they are deleted from the cad (and address appears instead)
Is there a way to show the pictures while forcing revit to not export the picture files in the same location??
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: NERDASORUS
Can't you reload the image from a different location?
See "Reload From"
Manage Images Dialog | Revit Products 2020 | Autodesk Knowledge Network
Nachricht 3 von 3
syman2000
Sadly Revit will export CAD with the image at the same folder. If you want to change the path, you can use AutoCAD reference manager
All you have to do is add all the export CAD file. Then in the path, you will see image path. Select those image and edit the path. Then pick the new location of the file. Once you done, then click on APPLY CHANGES button at the top.
