Printing to pdf and exporting DWG from REvit
Message 2 of 12
What are the fastest ways to print to pdf and export to DWG with the files named as the firm standards and no need to rename the files afterwards, is there any?
Thank you
Replies (11)
Message 1 of 12
Thank you
Message 3 of 12
Hello @Anonymous
You should select under Print range the "Selected views/sheets" then save the sets and continue PDF printing. And during exporting DWG select the Set you save during printing to show all the sheet or views you wanted to export.
Please refer to Images
Message 4 of 12
planimo
Hello @omar.ashraf
Is use "RTV Tools" and "PDFCreator" it is perfect to print pdf and export dwg in a single step.
Message 5 of 12
This is the standard way printing or exporting to pdf, what i meant is,
when you do this, you need to rename each file afterwards
thank you anyway
Message 6 of 12
@Anonymous
Do these require renaming each file afterwards, or they just get the naming from the sheet name and number as well as the project number?
Message 7 of 12
There is an app called RVT exporter or something like that can do what you want, I think. I never use it but I have a free file renaming app that can rename hundreds of file in seconds.
Message 8 of 12
@ToanDN
There are a lot of renaming apps on the web, may you please tell me the name of the one you use or the best one.
Thank you
Message 9 of 12
Message 10 of 12
Get XRev Transmit...  it reads project and titleblock parameters in its naming process, including shared parameters.
Also you can print and export at the same time....it also comes with its own PDF Emulator.
Message 11 of 12
Message 12 of 12
Viveka_CD
