Printing Sheets to PDF issues - text overlaping and drawing position wrong
Trying to print to PDF and receive output similar to the attached with text overlapping and drawings not being in the right position.
Using a new MS Surface Pro tablet
Changed to print both vector and raster - same with both settings
Installed CUTE PDF writer and printed using it instead of the Adobe PDF printer - same issue
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
Which version of Revit are you using? Can you confirm if you have the latest updates installed?
Please check your system requirements and hardware requirements.
Let me know if you have additonal questions.
Using v2018.3
Found the problem.
The text was missing a font type (Arial Narrow) and tried to used Arial Unicode MS instead.
Once the font was in place, the text and printing appears normal.
Viveka_CD
Hi @Anonymous
Thanks for sharing the update with us. I'm glad to hear that your issue is resolved.
Which surface book configuration do you have?
Windows 10 Pro
i7-8650U
16GB Ram
Nvidia GTX 1060
1 TB SSD
