Printing shadows/rendered images tiles the image
2 ANTWORTEN 2
Nachricht 1 von 3
433 Aufrufe, 2 Antworten
I'm having a relatively new problem printing anything other than hidden line drawings. Anytime I set shadows or any sort of color to the view, the image tiles itself across the page (please see attached image).
I use parallels, which will probably be your first thought, but I had no problems up until I upgraded to Revit 2018.
I've installed the Bonjour driver in Windows (v10), uninstalled and re-installed my printer driver through Windows, and I've tried Cute PDF & Print to PDF.
I've seen lots of forum posts about trouble printing in raster, but I haven't found anyone describing the issue as "tiling the image." Any thoughts would be appreciated!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
+1 I get the same issue. Similar setup (Parallels + Windows 10 + Microsoft Print to PDF).
Nachricht 3 von 3
dmitchell
Same problem with Parallels, Windows 10, any PDF software (Bluebeam, Microsoft PDF, PDF Creator).  See my post for more examples.
https://forums.autodesk.com/t5/revit-architecture-forum/pdf-of-multi-viewport-sheet-shows-multiple-a...
Still haven't figured it out.  Doesn't happen on all systems and only certain sheets in a model.  Maybe it is a parallels thing, but I try to setup each Parallels installation the same on all systems.  We probably have three computers that have this problem with the same models, same sheets.  Pulling my hair out.
