Printing PDF from Revit
13 ANTWORTEN 13
Nachricht 1 von 14
1618 Aufrufe, 13 Antworten
Hi everyone!
One of my colleague has problem printing pdf from Revit. As a matter of fact when he opens the pdf printing setting window, there is no setting and it's empty. We have checked the update for adobe and Revit, we have reinstalled Revit and adobe but it didn't help.
Is there anyone who has a solution to fix this issue? any idea is appreciated.
Tags (4)
13 ANTWORTEN 13
Nachricht 2 von 14
martijn_pater
als Antwort auf: Anonymous
Install a (new) PDF printer, there are a lot of good printers around... ie. bluebeam / pdf creator / pdf architect / foxit
Nachricht 3 von 14
MostafaElashmawy
Are you using the latest hotfixes of Revit.
Also check if clicking on the Edit button will open Adobe settings.
If yes, I may think that this is an issue related to graphics driver. Make sure to update it. That's just a guess and may be wrong.
Mostafa Elashmawy
Nachricht 4 von 14
als Antwort auf: MostafaElashmawy
It's not possible to open the Edit, it's empty. we have installed all the updates for revit.
Nachricht 5 von 14
MostafaElashmawy
I propose to make clean uninstall for revit as per attached link.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
By the way, is Printing to PDf working from other Autodesk software? Autocad for example.
Mostafa Elashmawy
Nachricht 6 von 14
martijn_pater
Don't think it's a Revit issue, probably it's just the pdf printer that needs reinstalling/repairing.
Nachricht 7 von 14
Reinstall Adobe PDF or another PDF printer. I would give PDF Architect a go.
Nachricht 8 von 14
Karol_Piroska
Get xrev transmit - it will save you literally hours
Nachricht 9 von 14
An even better solution is to use a Revit plugin from the Autodesk app store that can take care of exporting to PDF, instead of using the buit-in printer and a PDF driver. The main advantage of using a good plugin is the auto-detection of sheets, naming, and project-based settings that can save you a lot of time. The plugins are also tested by Autodesk so they work well.
Nachricht 10 von 14
joao.teixeiraVPJZQ
ProSheets will do it all for you. You can easily save different settings to different profiles, use Revit parameters automatically save the PDFs accordingly to the naming conventing you wish. It can also export to DWG, DGN, DWF, NWC, and IFC at once!
Nachricht 11 von 14
als Antwort auf: joao.teixeiraVPJZQ
Hi, I downloaded ProSheets for Revit to print sheets in pdf. However, when printing Arch D size, there is either a margin on the sides. I played with the setup and figured out a way to "fit" ARCH D title block but there is still an inch extra on the top. I don't get why this is happening. Shouldn't there be one specific ARCH D size universally? Then how come revit doesn't recognize it when printing?
Nachricht 12 von 14
luisPDAN6
Have a go with this app from the Autodesk App Store instead. I think it should take your D size with no problems. Is your titleblock exactly D size in the edges or larger? It should be exact to work anyway.
Nachricht 13 von 14
joao.teixeiraVPJZQ
@Anonymoushave you also set the offset from corner to "No Margin"?
Nachricht 14 von 14
Got it! Thank you so much!
