Printing line weight below .003
5 ANTWORTEN 5
Nachricht 1 von 6
599 Aufrufe, 5 Antworten
Can we please remove the .003" limit. AutoCad can go much lower. In today's world we don't print as much and a lot of our graphics/drawings are digested digitally. Having a smaller lightweight would be very helpful to the clarity of our drawings.
5 ANTWORTEN 5
Nachricht 2 von 6
loboarch
als Antwort auf: Anonymous
There is an idea for this at the Idea Station. I would suggest you add your vote there (if you have not already) and add any comments you might have as well to make the issue more clear to the product team why this is important to your workflow.
https://forums.autodesk.com/t5/revit-ideas/improve-line-weights-for-small-scale-drawings-remove-003-...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 6
als Antwort auf: loboarch
Thank you Jeff,
i have done so. I just wish autodesk would fix all the “small” things that affect us day to day. Would actually be a lot more helpful than the larger more marketable changes typically made.
Nachricht 4 von 6
I can get down to .001"/0.025mm....which is still smaller than the technical pens of yesteryear.
Nachricht 5 von 6
What happens when you print? When I print to pdf it bumps up any LW below .003
Nachricht 6 von 6
You just think that you can (as Revit will makes you think that you can print 0.025mm). In reality, when you pdf or print any lines thinner than 0.083mm it will become 0.083mm thick.
