Printing issue when splitting a schedule across multiple sheets
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
vincent6062
1272 Aufrufe, 4 Antworten
Dear all,
I split a schedule of accommodation onto three A3 sheets as per below snipping:
Sheet 1Sheet 1Sheet 2Sheet 2Sheet 3Sheet 3
When printing though I get an unexpected result for sheet 2 and 3. It looks like Revit keeps printing the beginning of the schedule and does not want to print where the title block is placed. See images below for clarification:
Sheet 1 printedSheet 1 printedSheet  2 & 3 printedSheet 2 & 3 printed
Is there a way to make Revit print sheet 2 & 3 properly?
Kind regards.
Vincent
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: vincent6062
You have to keep all the unwanted schedules to the right side of the border and above the bottom of the border and set the paper placement to Offset from Corner, not Center.  See illustration.
Nachricht 3 von 5
vincent6062
als Antwort auf: ToanDN
Thank you ToadDN. It is working :leicht_lächelndes_Gesicht:
Nachricht 4 von 5
julian.bokej
@ToanDN moving "unwanted" part of schedule to the right side modifies the schedule on all sheets. Therefore this workaround can only be used if you print one sheet at a time and move the schedule again. Is this is what you meant?
Alternatively I could duplicate schedules, but then I would need to keep track of all of them.
Nachricht 5 von 5
als Antwort auf: julian.bokej
Revit 2022 can place child schedules independently on different sheets.
