Printing in Revit settings to get it fit a page
3 ANTWORTEN 3
Nachricht 1 von 4
AidanHawkins
336 Aufrufe, 3 Antworten
I want to print directly from Revit
However it wont let me fit to an a3 page
The drawing is A3 and I select print size to be A3
However it is always smaller than A3 and leaves blank space on the sides
Can anyone help
Regards
Aidan
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: AidanHawkins
Nachricht 3 von 4
als Antwort auf: barthbradley
Print 100%.
Nachricht 4 von 4
luisPDAN6
If no element in the titleblock is bleeding out of the edges to the titleblock it should be able to print 100% match to the paper size. With the Docuflow plugin it is easy to see the actual size of the Revit sheet, even when it is larger than the expected size by some reason, and solve that sort of problems. Docuflow prints 100% by default so the PDF always matches even with non standard sizes.
