Printing Half Tone (Not able to see on PDF)
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
info
547 Aufrufe, 4 Antworten
All fixtures I made half tone (using VG). But when I create a PDF. There line work is black?
Please see attached.
4 ANTWORTEN 4
Nachricht 2 von 5
HVAC-Novice
als Antwort auf: info
Are you exporting to PDF from Revit, or printing via 3rd party PDF printer? did you try different methods to create PDF?
Revit version: R2025.4
Nachricht 3 von 5
info
als Antwort auf: HVAC-Novice
Thanks for your post,
Yes. I'm printing to MS Edge (3rd party) PDF.
It's strange, Half -Tone works  (when printing) but not in all instances?
I went over all items in VG & set project line type to a "grey" - that seemed to print correctly - it's just time consuming.
Nachricht 4 von 5
HVAC-Novice
Try the Revit PDF export option or a better PDF printer.
Nachricht 5 von 5
info
I think I found the problem,
In Print Settings;
Uncheck - "Replace halftone with thin lines"
That allows to print correctly.
