Printing from Revit 2023 on a Macbook Pro (M1 chip) Running Windows 11 on Parallels
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
JP-HNA
1312 Aufrufe, 6 Antworten
I just bought a new MacBook Pro with an M1 chip and I'm having some challenges printing in Revit 2023.
On my old MacBook Pro, I ran Windows 10 on VMWare Fusion.  No longer possible with the M1 chip.
So, I switched to Parallels, and also had to switch to Windows 11.  Then I installed Revit 2023.  So far, so good.
I used to use Primo PDF to print, but it appears Primo PDF isn't ready for Windows 11...
Any suggestions on a free PDF printer that works with Windows 11?
Also, in the print dialog, how do I create larger sheets (Tabloid, 11" x 17", 24" x 36")?
Thanks for any help!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: JP-HNA
Export to PDF directly from Revit File menu.
Nachricht 3 von 7
JP-HNA
Thanks, Toan!  Wow.  I had no idea that was there.  I’ve been printing the old way for so long, I didn’t realize that a PDF printer was built in!
Nachricht 4 von 7
Joe.MillerB2UVJ
Hey James,
Just curious how revit 2023 runs on your apple silicone, and how much RAM you recommend?
Nachricht 5 von 7
JP-HNA
als Antwort auf: Joe.MillerB2UVJ
Joe,
I have had no problems running Revit on my new MacBook Pro.  I have 32 G of RAM, and it has been sufficient, with no noticeable lags.
James
Nachricht 6 von 7
biztrobill
Same here. Revit LT in Parallels is very quick with 32 GB (which means 16 GB is available for Parallels), but I believe the faster processor matters too.
Bill Fowler NCARB
Revit LT Suite 2024
Mac M2 Pro Mini, Apple Studio Display; w/ macOS Ventura, Parallels 18, Windows 11. 32GB memory (Parallels assigns 16GB for Windows virtual machine)
Solo Architecture practice in residential and small commercial design.
Nachricht 7 von 7
biztrobill
But, back on topic...
I think Bullzip is a really good PDF printer. It can add the current date to the PDF file name if you want - something Revit just won't do. But they haven't updated Bullzip to work on Mac M1 or M2 devices, so I use the built-in PDF printer now. Works fine.
Bill Fowler NCARB
Revit LT Suite 2024
