Printing - dialog box does not pop up
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
3805 Aufrufe, 4 Antworten
I'm trying to print by selecting sheets.  The dialog box does not pop up when I hit Select in the Print dialog box. The Setup dialog box also does not pop up. This is the first time I've attempted to print anything from this desktop.  I'm using Revit LT.  I'm not sure if it is relevant to my issue but my PDF print option is "Microsoft to PDF".
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Go to Windows printer settings and choose a different one as Default printer.
https://forums.autodesk.com/t5/revit-architecture-forum/microsoft-print-to-pdf-was-nonresponsive/m-p/7259911#M157443
Nachricht 3 von 5
Viveka_CD
Hi @Anonymous
Welcome to the community!
I just wanted to follow-up here, any progress on this issue? Were you able to resolve your issue?
See HERE for a similar post.
Let us know if further assistance is needed from the community on this post. Looking forward to your reply update.
Please mark any posts that help with "Accept as Solution" and thanks!
Nachricht 4 von 5
rimacoca
als Antwort auf: Viveka_CD
Open the revit
Open the sheet and select the title block
Print
if is not working
Close the revit
Install a new virtual PDF printer
 Example - www.pdfforge.org/pdfcreator/download
Open the revit
Print
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
Nachricht 5 von 5
Try minimizing Revit. We have some weird thing going on like that around our office at times, and one guy found it by accident. The window does pop up, but not in the correct "draw order". Hope this helps.
