How do you print as a PDF when the drop down only provides the printer or FAX as an option? Is there a way to load PDF as an option if it's not already there?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@Anonymous wrote:How do you print as a PDF when the drop down only provides the printer or FAX as an option? Is there a way to load PDF as an option if it's not already there?
What do you normally use to create PDF's? If you're in a bind, go grab a trial of Bluebeam Revu. They have a great plugin and driver for Revit. The trial is for 30 days.
I normally just print through the Revit program itself. Typically, when you click print, there's a drop down option that says PDF. When you go to print, it automatically saves it as a PDF. But I will give your suggestion a try, thank you!
