Hello everyone ![]()
I'm updating my titleblock/sheet at Revit 2023.1.3 (23.1.30.97) and I came across with this curious 'hitbox' issue in this generic annotation, if the horizontal align of the text are Left or Center, the 'hitbox' is detected by the frame/border of the generic annotation, but if 'Right' is selected at the horizontal align of the text, the 'hitbox' is far away from the frame/border. This issue is a kind annoying because afects the printable area of the sheet.
I'm doing something wrong or anyone know how to solve this?
Kind regards
Upload the file so we can take a look.
Use a label in the titleblock family to report the sheet size.
You do not need to use a nested generic annotation family.
Thank you for your reply.
I've uploaded the file on the first post, so you can take a look.
Thank you for your reply,
I have used a generic annotation because I need to control the position of this tag in the sheet.
I just remade the label in the generic annotation and it is working fine for me.
Might be some sort of holdover bug from if you had previously had the length of the label much longer.
Generic annotation works fine. This reference line cause the page to shift.
If you set it to 25mm, the page no longer shift.
Thank you for everything guys, but you could share your tests/solutions?
To be honest, none of them work for me. I try several times making a new generic annotation, also I tried do it in a previous release of Revit 2023 (2023.1.1) and in another PC, also do it on Revit 2022, and i've tested in a completely new titleblock family, and I reached always the same conclusion, Generic annotation is detectable far, then should do it.
So if you get a good result, probably I'm making something wrong
Thanks one more time to everyone.
