Hi fellas!
We need to print vectorized drawings for our customer (demand). But our facades seems to print as raster.
I've checked the following below:
"Revit automatically uses raster processing for a view if any of the following are true:
And can't seem to find any of those categories. Anything else that can mess the print up and print it as a raster instead of vector?
Gelöst! Gehe zur Lösung
Gelöst von Marcus.Isacsson. Gehe zur Lösung
Are you sure there is no depth cueing?
Could you please share the printed PDF from that view? I would like to see, if everything is raster or only some of those objects.
@Anonymous wrote:Could you please share the printed PDF from that view? I would like to see, if everything is raster or only some of those objects.
We just found it, there was a picture inside the sheet template. My bad! Thanks for helping out though!
Good to know @Marcus.Isacsson ![]()
Here are some Best Practices: Printing that will be helpful for the community seeking similar answers.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
