Hi @Anonymous,
There are many topics about this in this Forum, you can search or you can also use the link below with the formal explanation:
Hi
Install a PDF printer like
1. Adobe Acrobat
2. Nitro
3. CutePDF
If nothing is available then check default " Microsoft Print to PDF"
PrinterTHere is a restriction of Print size, for example maximum size PDF possible is A3.. in that case use the reduction percentage and create PDF..
This table might help you... For example Converting A1 Sheet to A3 size pdf, 50% reduction is required... you may use
the combination which suits your project sheet size...
| Size | A3 | A4 |
| 4A0 | 18% | 12.50% |
| 2A0 | 25% | 18% |
| A0 | 35% | 25% |
| A1 | 50% | 35% |
| A2 | 71% | 50% |
| A3 | 100% | 71% |
| A4 | 141% | 100% |
| A5 | 200% | 141% |
| A6 | 283% | 200% |
| A7 | 400% | 283% |
| A8 | 566% | 400% |
| A9 | 800% | 566% |
Best luck
Cheers
@barthbradley Thats looking awesome... Never got a chance to use that..
So many options in printing... just that users are locked sometimes with the companies default system.
I was luck to have Adobe Acrobat, X-Rev and few more...
You could be fined for cultural misappropriation of language for that title....
