Print to PDF Text Zoom
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
rzimmerman85WE2
1537 Aufrufe, 5 Antworten
I'm PDF'ing a couple 30 x 42 sheets at 100% scale and all text on the page is zoomed larger for some reason. The titleblock fits the 30 x 42 window, but all the text within it is too big and all of the general notes and legend text on the sheet itself are too big. When I look at the sheets on my monitor, everything is scaled correctly. I'm not sure where the disconnect is happening. I tested on Revit 2019 with no issue, it seems to just be Revit 2020 that's giving me an issue.
Appreciate any help!
Tags (1)
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
mauricio_mssf
als Antwort auf: rzimmerman85WE2
I've seen a similar problem and it had to do with the microsoft surface screen resolution.
Microsoft Surface comes with a high-resolution display.
Please see How to set custom screen resolutions on Microsoft Surface
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 6
rzimmerman85WE2
als Antwort auf: mauricio_mssf
Is it similar if I'm working on a desktop? I checked my display settings and it looks like I'm using the recommended settings.
Nachricht 4 von 6
_Vijay
Did you tried any other PDF exporter such as BLUEBEAM or foxit reader. May be it will solve your problem.
Nachricht 5 von 6
rzimmerman85WE2
als Antwort auf: _Vijay
That was a good thought. I had been PDFing using BlueBeam and I asked my coworkers what to do and they recommended PDF Creator. I just tried it and encountered the same problem :verwirrtes_Gesicht:
Nachricht 6 von 6
rzimmerman85WE2
My computer needed to run an update and restart and that fixed the problem :leicht_lächelndes_Gesicht: Thank goodness
