Hi.
I got a Revit 2020 file in which DWG files are linked in it.
When I try printing to pdf, some colors changed on pdf. Normal Revit view has true colors.
I tried to change from vector to raster.
Colors solved but resolution problem is huge.
Any idea?
Please help.
Is there a solution to this? same problem rvtt 2019 print preview is ok, pdf b/w...
Have you tried Hotfix and see if that helps?
like sysman said, try installing the hotfix. I never encountered this problem in Revit 2020
