Print to Bluebeam PDF Orientation Issue in Revit
5 ANTWORTEN 5
Nachricht 1 von 6
3710 Aufrufe, 5 Antworten
When printing a View/Sheet Set from Revit some of the sheets are randomly changing orientation from vertical to horizontal. Although it's not a big deal to go into the handful of PDF's, change the sheet orientation and save, it is rather annoying. Anyone else run into this issue and if so is there a fix?
Specs:
Revit 2018.3.1
Bluebeam Revu 2017.0.40
5 ANTWORTEN 5
Nachricht 2 von 6
pendean
als Antwort auf: Anonymous
This is not the REVIT forum, that is over here https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
Bluebeam is not an Autodesk product: Bluebeam support is over there https://support.bluebeam.com/
Nachricht 3 von 6
Viveka_CD
@Anonymous
Can you share a screencast and a file to investigate further?
Is your Bluebeam PDF printer updated with the latest driver from the manufacturer's website?
Nachricht 4 von 6
Viveka_CD
als Antwort auf: pendean
Hi @Anonymous
Just checking back if you've had a chance to send me a file to test?
Do you still get the error?
Nachricht 5 von 6
Patricia_Villar-HPA
I am experiencing the same issue
Nachricht 6 von 6
mknuppUWQKG
