Print sketchy plan to PDF on Titleblock
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
1166 Aufrufe, 11 Antworten
I am using Revit LT 2016.  When I print from the 1/4" plan view, the sketchy lines for the walls appear and look great, but when I go to the title-block to  print the same plan the sketchy lines for the walls do not appear.
I should note that there is one view that I can print to pdf from the title-block and that is the site plan.  The  view is at scale 1:40 and the sketchy lines print great.  I would love to be able to use this same effect for the rest of my plans and print directly from the titleblock.
11 ANTWORTEN 11
Nachricht 2 von 12
bimscape
als Antwort auf: Anonymous
Have you tried changing the scale of the plan view and seeing what effect (visually) this has when viewed on a Sheet (ie on a titleblock family)?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 3 von 12
Viveka_CD
Hi @Anonymous
Can you share some screenshots from the Revit preview and PDF prints?
Which PDF printer do you use and have you tried this with other PDF printers?
Nachricht 4 von 12
als Antwort auf: bimscape
Thanks, but I tried changing the scale, but it didn't change the outcome.
Nachricht 5 von 12
I believe that you can only print Raster with Sketchy Lines enabled.
So be sure you have Raster selected instead of Vector.
Nachricht 6 von 12
Thank you for you help.  I have tried using Raster and using Vector and I have used PDF 995 and Adobe PDF.   I have also tried using color, gray, and black.
I have uploaded a pdf of what it looks like when I create a pdf from the titlesheet.  The view on my screen looks 'sketchy' but when I print it, all the walls are missing (see pdf).
I also have uploaded a pdf of what it looks like  when I print a pdf straight from the view, which looks great.  I just can't figure out why it will not create a pdf with these 'sketchy' lines on a titleblock.
Thanks for you help!
Nachricht 7 von 12
Thank you but I tried this also but it still prints the pdf without the walls.  Let me know if you think of anything else.
Nachricht 8 von 12
Does the view have a custom crop region?
Nachricht 9 von 12
Viveka_CD
Hi @Anonymous
Can you send us the file to investigate? I can share a private upload folder for you.
Nachricht 10 von 12
als Antwort auf: Viveka_CD
Yes that would be great! I will look for the private folder so that I can upload the file.
Nachricht 11 von 12
als Antwort auf: ToanDN
Yes it does!!  I just removed the custom crop region and it now prints the walls on the title-block!  Wow that's great! Thank you!!!
Nachricht 12 von 12
Thank you for your willingness to help but we just figured out that it was the custom crop region that was not allowing it to print to pdf in sketchy mode!!
