Print setting
Print setting
mahanmotamedi1991
Print setting
mahanmotamedi1991
Hello Everyone,
I have a question about printing the sheets with high quality.
Attached you can see two screenshots. First is the screenshot from my plan where I zoomed in on the interface with sheet scale (ZS). Supposedly I expect to have the same quality when I print the plan in PDF, but as you can see in the second screenshot, I have a terrible quality image with thick lines and hatches. Do you have any tips on getting the print quality, such as what I see on the interface?
PS: I set the pdf export setting on high quality and put all the lines thickness on 1.
Best,
RDAOU
@mahanmotamedi1991
If you are or want to print the visible portion of a view window (ie: what is visible on screen) using scale to fit,
  1. change the scale of the view to 1:1 first
  2. then Print PDF
  3. Set scale back as before
You see thin lines in Revit because you toggled Thin Lines on.  Toggle it off (type in TL from your keyboard or from the ribbon) to see the actual line weights on screen.
Then if what you see on screen is not what you want then you need to understand and edit Line Weights table, and/or Object Styles, or Visibility Graphics Override to get what you want.
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Ho...
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-D...
