Print PDF thin lines
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
21708 Aufrufe, 7 Antworten
I'm using Revit 2015. Problem with line weight when printing into PDF . How to get thin lines? I've set LINE WT to 1.(Manage>Advance setting) and visual graphics set to 1. But doesnt work. Pls advise.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Check your line weight settings for the scale of your views. Make pen #1 be as thin as you want.
I have pen #16 as my thinnest possible as Pen #1 controls model patterns and Pen #2 controls ceiling patterns.  #3 - #8 are my standard lines.
Nachricht 3 von 8
Thanks for reply. My scale is 1:300 and there are limited pre-set scales. How do I custom scale?
Nachricht 4 von 8
So I believe it will grab the next closest scale....so make sure you have a 1:200 and 1:500 created...it should jump to the next scale for custom scales.
Nachricht 5 von 8
Thanks very much. Lines are thinner now but not as thin compared to AutoCAD. I suppose its the printer problem? I'm using CutePDF free version.
Nachricht 6 von 8
Revit isn't Autocad.  It knows that a printer can only go so thin.
If you want it to go thinner export your view to Autocad and print to PDF from there.
Nachricht 7 von 8
shaheer
Nachricht 8 von 8
rinatkazantsev1
Ensure you've prepared scales for 1:200 and 1:500. The system will automatically switch to the nearest scale if a custom one isn't available. Regards (Puff Print Manufacturers)
