Print Page Scale
4 ANTWORTEN 4
Nachricht 1 von 5
jfjacques
362 Aufrufe, 4 Antworten
Print Page Scale
Everything seems fine in the PDF. I get one page that seems to print at a completely different scale.
What could be causing this?
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: jfjacques
Does that Sheet have a different Titleblock family?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
jfjacques
als Antwort auf: cbcarch
No it's the same.
Nachricht 4 von 5
"Seems" to?  You're not sure?
Is Zoom set to 100%?
Nachricht 5 von 5
- Nothing should be outside of sheet border. If you need to keep something out of the border, they must be on the right and above the bottom of the border.
- Print 100%, not Scale to Fit
- Paper placement should be Offset from Corner, not Center
