Is there a way to have my A-Sheets print with just there name, ie A-101, without having all this extra stuff added. I've tried printing with just an underscore but it still adds the word "sheet" to each filename (See image). I had to manually rename the files as shown in the attached.
Not out of the box. I bet some printing add-ins can do it. But I just let Revit print sheets with full number and title and use a batch file renaming utility to fix it. Do it for hundreds of sheets takes less time than me typing this.
No, you have to remove it manually, but you can do that before it actually prints. Minimum, but still effort unfortunately...
Of course, there are addins which can fix it, or you can batch rename them yourself.
