Print Multiple Sheets into PDF
Hello. How do you do when you need to print multiple sheets into pdfs with one click?
Thanks!
L.Maas
You can not. You will have to use the Print function and set it up as you need.
You can select multiple views/sheets and print them to multiple or a single PDF.
If you want to do it with a single click you would need to automate/program it and create an add-in.
Louis
Please mention Revit version, especially when uploading Revit files.
@L.Maas
Is complicated to automate or program it? Could you brief it here?
As @L.Maas said there is no quick way to batch print to PDF from Revit without confirming the name of each individual file.
Please see the following link to download a free trial from the exchange apps website. It is really easy to use,  give it a try and see what you think.
https://apps.autodesk.com/RVT/en/Detail/Index?id=3151313819991491909&appLang=en&os=Win32_64
@Anonymous
only bad thing is only 14days trial..
Archigrafix_Norge
You can print sheets with one click using Docuflow that is available in the Autodesk App Store.
Luis Santos
archi systems as
