Print hidden line vectorized?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
2306 Aufrufe, 5 Antworten
Hi guys! I have a problem, I want to print this 3d view vectorized,Cattucsdscscscsra.JPG so I can change it in Illustrator! But when I try to do it this error message comes out
I switched off the shadows.
Do you have any suggestions?
5 ANTWORTEN 5
Nachricht 2 von 6
cbcarch
als Antwort auf: Anonymous
Printing the View will not export a vector file type that you need for Illustrator.
Try exporting the view to Autocad or from a Sheet with the View on it.
This should give you a 2D vector format file that you can use in Illustrator.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 6
als Antwort auf: cbcarch
Thank you for your answer! I tried to export in dwg, but it exports all the lines, like it were in wireframe.
and i tried to use the sheet too, but the error is the same as before, saying that is gonna print in raster.Catturascsdcscs.JPG
Nachricht 4 von 6
cbcarch
Do not Print--use Export to Autocad.
You might also try exporting an .eps file.
  1. Click Application menu Export Other Formats.
  2. In the Export Data dialog box, specify a location and file name for the EPS file.
  3. Under Files of type, select Encapsulated PS (*.eps)
  4. Click Save.
Cliff B. Collins
Nachricht 5 von 6
Thank you it worked! So I had to export the sheet in dwg!
Nachricht 6 von 6
You must have set the view to have some visual effects such as Silhouette or something.  I can print any hidden 3D views to PDF as vector format without any sort of warning.
