Print Distortion
Print Distortion
Jonathan.Jones3VH4QT
Print Distortion
I'm having issues where my 3d views look fine onscreen, however they print with distorted parallel lines along the face of walls, topo, etc. I am using the bluebeam printer.
I've been looking for the fix but have not been able to find the issue. Help please!
Lachlan-JWP
Are you printing a view from Realistic visual style? The nearly vertical lines on the walls look like a repeating pattern from the render material.
The horizontal lines on the floor component look like they align, but it looks like a different material.
Correct these are using the realistic visual style. It's not a pattern of the material itself.
Lachlan-JWP
Do the lines still appear when you use another PDF printer?
It might help if you could post the file.
Yes they do. I tried the different print options to rule that out.
Unfortunately it's a huge file. Over the size limit
Lachlan-JWP
Save a copy of the file and delete everything except the elements that we could see in the image you linked. That should reduce the size enough to upload.
